AOD to C4
AOD to C4
Hello, I am new to mustangs and I just bought a 90' lx 5.0 It has the AOD transmission and I would like to step up to a c4. What needs to be changed? Will the driveshaft need lengthened or shortened? Will the crossmember and mount work? Flywheel need changed? Thanks
RE: AOD to C4
I put a C4 in mine where an AOD once was. I had to move the crossmember up about 2 inches or so. Mine was an adjustable one, so all I had to do was cut the tack welds loose, slide it forward and tach it back. I used an aluminum drive shaft in mine but I hear the original drive shaft will work.
