Project:Teal Beast
RE: Project:Teal Beast
Removed the water pump and timing cover tonight. Looks like I am gonna have to pull the motor out completely now cause as i was removing the timing cover part of the pan gasket stuck to the timing cover and tor the ruber. Was realy hopin to til the motor enought to pull out the old cam and drop in the new one and swap out the motor mounts. More pics below.....well got a new camera and the files are to large to upload. Here are links to photobucket.
Test fit with new head
http://i324.photobucket.com/albums/k...z/IMG_0106.jpg
http://i324.photobucket.com/albums/k...z/IMG_0107.jpg
View of where i was left from the last work i did.
http://i324.photobucket.com/albums/k...z/IMG_0108.jpg
http://i324.photobucket.com/albums/k...z/IMG_0109.jpg
http://i324.photobucket.com/albums/k...z/IMG_0110.jpg
Water Pump Removed
http://i324.photobucket.com/albums/k...z/IMG_0112.jpg
Timing cover removed
http://i324.photobucket.com/albums/k...z/IMG_0113.jpg
Pic of New head.....Ya I was going Pic happy tonight
http://i324.photobucket.com/albums/k...z/IMG_0115.jpg
http://i324.photobucket.com/albums/k...z/IMG_0116.jpg
New BBK SSI race series Intake
http://i324.photobucket.com/albums/k...z/IMG_0117.jpg
http://i324.photobucket.com/albums/k...z/IMG_0118.jpg
Water Pump Removed
When you buy a timing cover gasket set, it will come with the front section of the pan gasket that the cover goes over. You just trim the old gasket off up to the block, put in the new pieces and you are good to roll....no need to pull the engine.
