Project:Teal Beast
#21
RE: Project:Teal Beast
BTW for those wondering why in all teh pics the motor looks wet....I'm not hosing it off with water. I am Misting the whole engine bay with WD40 to prevent surface rust thuse less rust to clean off when i am ready to put on the new parts. I still have to clean off the gasket surfaces from the old gaskets.
#22
I am gonna be pulling out the motor and cleaning up the engine bay.
what do most people use to seal up the unused holes? mig welder? Than afterwards bondo and block sand the area's?
#24
ORIGINAL: nseoi
u should was off that stuff before you start the car, seems like a great way to start a fire under the hood
My question is how do most people seal up those unused bolt holes?....Not basing or anything but ya got me confused there....
#25
Had to take a break from the project cause I had to open and close the store i worked at cause the other manager went on vacation for a week and a half....plus side Is I mad more money. Anyway early this week I ordered the Boss 347 from LRS along withsome other toys to go along with it. last night the oil pump, pick up tube and flywheel came in. Was like a mini christmas.
http://i324.photobucket.com/albums/k...z/IMG_0142.jpg
http://i324.photobucket.com/albums/k...z/IMG_0143.jpg
Tonight I removed most of the wireing harness's from the engine bay and cleaned up the passengers side front corner
http://i324.photobucket.com/albums/k...z/IMG_0144.jpg
http://i324.photobucket.com/albums/k...z/IMG_0145.jpg
http://i324.photobucket.com/albums/k...z/IMG_0146.jpg
#26
Pulled out the starter and remaning harness from the engine bay and pulled out the motor.
http://i324.photobucket.com/albums/k...z/IMG_0152.jpg - Motor
http://i324.photobucket.com/albums/k...z/IMG_0147.jpg - engine bay
http://i324.photobucket.com/albums/k...z/IMG_0148.jpg - engine bay
http://i324.photobucket.com/albums/k...z/IMG_0149.jpg - engine bay
http://i324.photobucket.com/albums/k...z/IMG_0150.jpg - engine bay
http://i324.photobucket.com/albums/k...z/IMG_0151.jpg - engine bay
Next is to start cleaning up the wiring and filling in the unused holes and giving it a cleaner Look. Mental not next time drain the trans before you pul the trans dip stick and spilling a few quarts of atf on the ground. LOL
#27
YAY More new parts cam in today!!! Still have to get in the engine bay to pill in the unused holes and smooth out some area's.
testing tried to resize this pic.
http://i324.photobucket.com/albums/k...z/IMG_0156.jpg
http://i324.photobucket.com/albums/k...z/IMG_0157.jpg
http://i324.photobucket.com/albums/k...z/IMG_0158.jpg
http://i324.photobucket.com/albums/k...z/IMG_0159.jpg
#28
Lubed up the new E303 ford racing cam with Comp cam & lifter Lube and installed it in the boss block. Than atacthed the timing chain. I need to figure out where I put my mustang manual, I don't remember where the timing marks on the timing wheels need to be exactly.
http://i324.photobucket.com/albums/k...z/IMG_0170.jpg
http://i324.photobucket.com/albums/k...z/IMG_0171.jpg
#29
went to a local junk yard in search of a timing cover for a sn95 model with failuer, will probably end up getting 1 from ebay but still ahve a few junk yards to hit before I do. put in the oil sensor and added some tubing to install a mechanicl oil pressure guage along with the stock one. pictures will be below. test fit the GT40x heads with the rest of the stuff going on the top end of the motor.
Close up of the oil sensor and mechanical guage hook-up
http://i324.photobucket.com/albums/k...ssurelabel.jpg
I am a little concerned about the throttlebody and the Egr they are sitting close to the valve cover, I may look into getting a throttle body spacer to try to remidy the issue.
http://i324.photobucket.com/albums/k...z/IMG_0180.jpg
http://i324.photobucket.com/albums/k...z/IMG_0181.jpg
More pics below...was to laxy to resize so click away on the links
http://i324.photobucket.com/albums/k...z/IMG_0176.jpg
http://i324.photobucket.com/albums/k...z/IMG_0178.jpg
http://i324.photobucket.com/albums/k...z/IMG_0179.jpg
