Project:Teal Beast
#41
installed crankshaft front seal on the timing cover housing. Installed timing cover gasket, and than torqed down timing cover to block. Ordered a new water pump from Ford and a crankshat bolt and washer.
#42
I started welding in the unused holes and filling large openings that arent going to be used. Started on the PS first.
Before
Used posterboard to fit a piece of sheet metal in before I started welding
Filled in a hole on the shocktower
On the PS fender 2 holes
welded 2 pieces of sheetmetal in
Close up of the 2 pieces connecting
Not bad for someone who hasn't welded in 10 years.
Before
#43
Project has been on hold for a while. had gotten a bit on the chilly side and than saving up funds for other things. Anyway I am planing to get the ball rolling again. Ordered a few things a few weeks ago and 2 items have came in.
1. Ordered a 6 speed kit from D&D with a hydralic clutch cable system Along with clucth and all the goodies. trans came in but not the rest of teh goodies.
2. A used Hydralic brake booster and master cylinder.
