oh, mah gawd
oh, mah gawd
im so ****ing excited
just ordered my AFR 165's, new valve covers, and lifters and such
all i need now is a gasket set (didnt quite have enough for it, were gonna get it from kragen) and pushrods (bought a single solid roller lifter and a pushrod checker)
Right now what i have
AFR 165cc 58cc Stud mount
Crane Cams, 2031
Scorpion 1.72 stud mount rockers, for 3/8 inch studs
OEM style Lifters
CnL 73mm MAF sensor calibrated for 24# injectors
70mm BBK TB and EGR
Edelbrock Performer 5.0
24# injectors that i just remembered needed new O rings and a flow test
ARP head Studs and Intake Mani Bolts
All new gaskets and such
Trick Flow billet Timing set
Black crinkle coat finned Mustang logo valve covers, short (which i will cut the baffles in to make them work with the 1.7's)
255lph fuel pump
and then the solid lifter and pushrod length checker
as soon as that **** gets here, the motors gonna come apart
im so excited, im as giddy as a school girl
Crane Cams, 2031
OEM style Lifters
70mm BBK TB and EGR
255lph fuel pump
RE: oh, mah gawd
its has a similar grind to an E cam, but with 1.7 rockers, lemme see if i can find the grind specs
Lift:
Intake @ Cam = 302
Intake @ Valve= 513
Exhaust at cam= 311
Exhaust at cam= 529
Ratio=1.7
Cam Timing at .004
Intake: opens at 28* BTDC closes at 68* ABDC Duration=276
Exhaust: opens at 75*BBDC closes at 27* ATDC Duration=282
Cam Timing at .050
Intake opens at 00* BTDC closes at 34* ABDC Duration 214
Exhaust opens at 47* BBDC closes at (7) BTDC Duration 220
Power range 1400-5400 almost the same as intake, Idle-5500
http://cranecams.com/?show=browsePar...tType=camshaft
Lift:
Intake @ Cam = 302
Intake @ Valve= 513
Exhaust at cam= 311
Exhaust at cam= 529
Ratio=1.7
Cam Timing at .004
Cam Timing at .050
RE: oh, mah gawd
im looking at some C/L and ebay finds, but i am le poor seeing as i just drained my account
im still needing some stuff, but not NEARLY as important
I.E i want to get an aluminum radiator and electric fan, for my overheating/coolant leak problem, and my loud as ****ing all hell fan problem
That Ignition ****, and one of the Tach+2 gauge pod that goes on the side of the gauge cluster
just to name a few
oh yeah, and the cobra bumper and LX catback, which is fairly close to the top of my list.
just to name a few
RE: oh, mah gawd
sounds like a good setup.. just a FYI im using stock ignition on my motor and it runs great.. As for the cooling thing, I just put in a fluidyne radiator and my car runs a hell of a lot cooler than it did with the stock radiator
RE: oh, mah gawd
you lucky sonofagun, can your job hire me so I can afford that stuff too? except I was looking at some Trickflow heads
but coilovers are next on my list, after subframe connectors
