IS THIS A GOOD DEAL!?!? zex dry nitrous kit
http://denver.craigslist.org/pts/768491429.html
need to know if this is a good deal.
ive been doing my research on n2o, but i dont know much about the install, or the parts that you need for the FULL KIT
i called him, he said the only thing the kit doesent include is the line from the bottle to the controler (he said it would be $50 for the line) and it doesent have any jets. (he said the jets are only like $10)
IS THIS A GOOD DEAL?!?!?!
what is missing from this kit?
any idea where i can get the missing parts?
if its a good deal, ill be going to pick up the stuff today (could someone previde a checklist so i can make sure this kit has everything?)
if it matters he said he only used the bottle about 3times before he upped his jet, and blew his motor[>:]
(it was a 4cly eclipse he used it on, started with a 55shot, and when he upped it to 75, it blew the motor.)
im planing on a 100shot to start with, as far as i know all i need is to run premium fuel, take my timing back down to 10*, and maybe bump down the spark plugs (if im forgetting anything please let me know.)
it would be nice to get a deal on this, but i want to do it right, so i dont hurt anything.
RE: IS THIS A GOOD DEAL!?!? zex dry nitrous kit
bump!
as far as i know ill be safe with 100shot dry, as long as i take down the timing, and use top grade fuel, right?
i have 2 ppl telling me its too risky!?
im more scared of a wet kit pooling fuel in my intake, and backfiring, blowing the intake off or something crazy, then a 100 dry shot....
plus its like $150 to get the hoses and junk to swap form dry to a wet kit. if i choose to up the shot form 100.
idk, all the research ive done says a 100shot dry, should be fine!!!
well it will be fine as if everything is up to par...and for your motor i would not go past a 100 dry shot. if you do want to go bigger then i would switch to a wet shot.
nvm, found a 150shot wet kit that comes with bottle warmer, in-car pressure gauge, purge, and the entire set up needed for install for $450!!!
so im jumping on it, considering new its worth $1100+
ha i got a steal on mine, i got a full Nos kit for 230 unused from my friends brother[8D]
only thing i needed was a pressure gauge, blow down tube, and purge.
ORIGINAL: Hollister Hoodlum
to be 100% honest man, your one of the first guys i thought of, when i was thinking who i would try to "educate" on nitrous!
its a wonderful power-adder as long as you do it right!
i think 90% of ppl are just dumb, and hard headed about nitrous.
heres some pictures
just wanted to see it in my trunk [8D]
nitrous gauge
le' bottle warmer
all the jets i could need.
