Oh my fing god finially, plus a question
RE: Oh my fing god finially, plus a question
why does that still seem to short for his setup ...
im not saying there wrong but on my 306 with a stage 2 tfs cam and stud mounted tqisted wedges im using 6.700...?
ORIGINAL: jtmustang
To woodsy and everyone who asked, they are AFR 165's
i dont understand this rollout thing, can anyone explain it to me
if it matters, Im using a Crane 2031, Lunati i believe stock style (almost exactly the same as the stockers) lifters, AFR 165 Stud mount heads, Scorpion 1.72 Stud mount rockers ona 3/8 stud
^^^i understand the thing about the heads im just saying that im almost positive that stock pushrods are too short for his setup . i knew a guy with a stock bottom end stang with afr 165's and a trickflow satge 1 and if i remember right his were 6.3-6.4 something...
and u said that it was almost dead center was it more to the outside or inside and rollout there talking about run it around a couple times to see as where it is all the way through the rotation...
also, by centered, i didnt mean side to side, i meant top to bottom, it went from what looked like almost center, maybe a little above at no lift,and was basically centered throughtout the motion not like left to right, up and down on the valve stem
Your looking for rollout between .050-.060 thousandths wide, meaning once you color the top of the valvestem with a black marker and run that rocker through 2 full cycles, the width of the mark left by the roller tip should be less than .060 thousandths of an inch. If the rocker is centered but the rollout is .100 wide, thats no good, if the roller tip seems to be a tad forward or a tad behind the center but rollout is .060 or less, thats your target. 6.2 seems awefully short, especially on a stud mount head
