GT40P heads worth $275 shipped?
#33
I've always been a fan of these right here..
http://www.tristatecylinderhead.com/...products_id=40
sure, its $600 for a set of GT-40P heads... BUT!!!!
60cc Combustion Chamber
Pedastall Type Rockers Used
Positive Oil Control Seals
5 Angle Valve Job
Stainless 1 Piece Swirl-Polished Under-Cut Stems 1.940” Intake Valves
Stainless 1 Piece Swirl-Polished Under-Cut Stems 1.540” Exhaust Valves
AWSF-32C Spark Plug
Springs Good to .550” Lift, (Hyd. Roller) *check cam manufactures specs for compatibility*
(129 psi @ 1.800” / 280 psi @ 1.300”)
they come with larger than stock valves, good springs, they show you the springs specs... How can you go wrong? sure, its $600 for P heads... but they are BUILT P heads
5 Angle Valve Job
AWSF-32C Spark Plug
#34
5 Angle Valve Job
AWSF-32C Spark Plug
5 Angle Valve Job
AWSF-32C Spark Plug
#35
5 Angle Valve Job
AWSF-32C Spark Plug
5 Angle Valve Job
AWSF-32C Spark Plug
Adder, should I just use the Explorer intake I bought (and pay another $100 for the stupid elbow) or should I pursue a Cobra intake?
Buyer's remorse sucks.
-Jordan
