valve springs
they are probably stock springs....hard to tell by looking at them, best way to gauge if they will be adequate is go have them tested if they are weak the last thing you'd wanna do is use them with a performance cam cause you'll never reach the full rpm potential of the cam if they float to soon
stock heads, looks like aftermarket springs. but like MJR said only way to tell is to have them tested
stock
difference
after
and i'm just curious about the rust in the cylinder cause mine came off like this....not sure what you have is normal. it doesnt look healthy though
stock
difference
after
one thing I noticed on your head after seeing the pice of 5pointoh's head are that your head do not have the factory exhaust rotator retainers on them..which means some one has replaced them with aftermarket retainers so it could have matched springs to the e-cam= different springs..have them tested to be sure
