they visited me on thursday....hopefully i'll have my gears in by the end of this weekend. the battery relocation was done today and starter heat shield blanket installed too(which solved my heat soak issues on my new starter)
what kind of ride issues? not high enough spring rate?
Correct
Originally Posted by FivePointOhh
that what i was thinkin....was it the springs that came with the tube k member kit? or did he specifically request the spring rate when he ordered it?
Yes, I went w/ what the guy recommended
Originally Posted by mjr46
Bernie can better explain the issue he was having, guess the tech gave bad advice there
The spring rate the guy recommended was 150. I wanted 175's but he said they would be too stiff and the 150's would work well. Here's what they look like with the weight of the car on them at the ride height my car is set at.
The coils are def compressed too much. As you can see, there's barely any room between the coils. So I bought a set of 14 by 200's from Strange. Hopefully, the'll go in next week.
