onyxcobra care to explain?? im a 21 year old idiot, with a clean record haha
roughly you need drag springs and struts, control arms, subframe connectors, a low gear (ie 4.10s), sticky tires and a little extra power and u could probably pull the front if you launched hard enough.
Hey man its not that hard to pull the wheels. All you need is a 408w w/ a demon 850 on it. Canfield 195 heads with a ~.600 lift cam. Hook it up to a TKO-500 and at least a 4.10 with sticky tires and your there. That setup right there with a good driver will go 10.8s allll day.
