Coolant and Over-heating Problem
Well now I got 175F electric fan (Flex-A-Lite) for my 1990 Mustang GT 5.0 (Manual). Also I installed Fluidyne 2 row aluminium radiator. When I drive for some miles, I can see the temp on my gauge climbs higher than what I used to have. Sometimes it over-heats and when I check on the coolant, it's almost gone (let’s say another 3 ltrs need to be added)!
Now, I am wondering where is my coolant ending up? I didn't have this problem at all before installing the fan & the radiator. I checked on all hoses everything looks fine with no noticeable leaks! I didn't suspect any other leaks, and last year I got my whole engine rebuilt and heads gaskets were replaced. After rebuilding the coolant level was great until I changed to Aluminium Radiator and the electric fan.
Please can you advise?
You are right, airlock can be an issue which I did not take into considerations. The other thing is that the thermostat was removed since ages. When I tried to put back a new one (180) , the temp. went up so quickly as the engine starts. So, I removed it!!!!
Do you think that with air pocket in the system, the coolant will be thrown out from maybe the overflow tank?!! because each time I need to add coolant to full then again it disappears! I am just trying to understand the relation between the airlock in the system and losing coolant everytime!
Yeah, i know dude you are thinking about the heater core, but right i checked it out, it's good. If the core is leaking, would it be easy to tell from inside the car, leak at passenger side? or sometimes, it might be tricky?!
No, you don't! The reason he was asking about the heat is when you have an air pocket in the system, generally there is no heat because of it.
Your cooliing system does take up like 14 qrts of antifreeze plus or minus some. I thought I was eating the coolant up awhile back until I read the capacities in the haynes manual. Fill it up and let it sit for a few then fill it up again and again. Eventually it will stop dropping. Then let the car run and wait till the thermo opens and fill it up some more.
Right, i missed that one! Any idea what could be the reason for losing the coolant each time while having air pocket? does it work to push some of the coolant out of the car?
