EFI TO CARB COMPLETE! PICS
looks good and so what intake and carb are u running?ahh what is a breakdown of the motor again?
and u say granatelli are u talking about their pickup with the an fittings for hookup , as i have the same thing for when i get a car again.
also so you hooked up the return side for the nitrous so is there a pump for that side or how did u hook that up as i am gonna run a shot on my next car with the same pickup and just curious as how you did it
thanks man
thanks man
thanks man
thanks man
https://mustangforums.com/forum/atta...1&d=1224689495
https://mustangforums.com/forum/atta...1&d=1224689520
oh wow man big ups on your completion im going the exact same way.a couple questions.
would it be better if you used the same diameter from carb to tank? for example why did you use a -10An and then all the way down to -6an? would it have been better if you used -8An from tank to carb?? how much gph are you running 130gph?
did you reuse anything from stock? how did you safely plumb the hoses under the body?did ou just close off all ports when you removed the smog pump?
