carbureted and turboed
how hard will it be already got the piping for the turbo and the turbo to the carb except for the plenum. Am I going to need to get a pump that is run off the belt? It's gonna be run up under the car, and with that said do I need an intercooler and where can I get a blow off valve(don't know if that's the same thing as a wastegate or not) it puts out a max of 7 lbs. and I've got about 260 (I think) to the wheels hopin that'll put me over 300 and that'll really liven it up
I mean for oil because I know that they need the oil 5.ohh do they make the 255lph for carbed cars and would I need to block off the place that the mech. fuel pump is. and to let ya'll know where I'm thinkin about puttin it is between the h-pipe so there won't be too much boost for pretty much a stck bottom end
you'll need special headers and a carb hat and a blow through carb...normal carbs won't work, and no a 255lph pump is for efi= not for your application.......outfitting your car for turbo will not be a quick nor simple project, after it is installed you'll need to tune it and make sure timing can be controlled, via a boost retard and have the proper exhaust for a turbo application
so am I going to have to put a Y-pipe on it or can I put it between the h-pipe like I was thinkin and would pro be able to help me out a good bit since he's already been through it where would I get a blow through carb and a bost retard
BOOST retard is just a ignition set up that is built in to msd box, summit sells them, and someone who I know has a better insight on this matter than I is a member named "uedlose"....he lives near me and he just built a turbo stang, and it is fast, although his is efi he still knows what he is doing as for the placement of the turbo I'd do the y-pipe with the reversed header set up so turbo is up front
if your turbo needs an oil line, you can tap into the pan,,,as for configuring the set up, I'm not sure if you can use your bbk's the way you intend to, either way it's gonna require fab work
