cobra intake (help me)
i am very new to the whole 5.0 scene and there are many things i dont really understand. i have found a lot of info on this site. but i do have 1 question will a cobra upper/lower intake froma 93 cobra fit on a 94 5.0 mustang and if so is that like the gt40 intake? thanks in advance guys
You will want the smaller valve covers unless you run an intake spacer. then you might have hood clearance issues. The taller ones are usually used on carb applications. The strut tower can not be changed. The brace however will be fine. If you use the elbow adapter then it will put everthing in the right spot. If you do want to run the spacer for the intake take the measurements on space between the intake and the brace now and see if there is enough room. I think you would need a 1 inch spacer. Its really not worth it because you can modify the stock valve covers to fit taller rockers.
jwog666
12-27-2021 08:09 PM
