8.8 rear end stop leak?
hi, my 8.8 rear end is leaking a little near the seal near universal joint . i don't want to tear it down right now. are there any stop leak or ? that i could put in the rear end that would stop it from leaking? thanks .
you can remove the flange and pinion nut and replace seal but also make sure there is not a groove worn on to the flange surface where the seal rides, in theroy you are suppose to install a new crush collor and reset pinion crush/ preload....but what I do often is remove pinion nut and flange , install new seal then reinstall pinion flange and nut and coat nut with thread lock and inside of flange splines with a little silicon sealer then tighten nut ligjtly with an impact until it stops spining then give it a blip or two with the impact....gotta do it real quick and feel it out so you don't over do it
When you change the seal buy the seal from Ford. I've had problems with Fel-Pro seals (I love Fel-Pro stuff) as well as other brands. The FoMoCo Seals are far and above better than any aftermarket seals. I've done probably 200+ 8.8 rear gear swaps and I've never had a problem with the Ford seal. I have had problems with the seals that come in Kits and from other places including Fel-Pro. One of the big advantages with the Ford seal is it has a sealing ring where the seal hits the housing. As I know of no other seal has it. It also has a wider sealing surface on the flange hub. If you use a Fel-Pro or another aftermarket seal where a long time FoMoCo seal has been and there is a very light groove the Fel-pro won't seal good. I keep at least 4 of the FoMoCo seals in stock all the time because I still do gear swaps for others. When the customer brings me their kit I just toss their seal and throw in one of the good ones. It cost me 11 dollars but won't be going under that car again. It's Reputation insurance, lol
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
