brake helpp
i have a 89 lx but i replaced the rear end im not sure with what yr but its disc brakes. i cant hook my rear brake hose up because on the line coming off the chassie nd then the line coming off the rear end both have the boxes where the brake line wouldhave the screw that screwd into them but i cant find a brake line with this type of setup
pictures might help. your wording is slightly confusing.
http://www.grassrootsgarage.com/imag...%20hose001.JPG
ok do you see how the bottom has the box on the end?? i need a brake line with the box on each end |
ok i need a brake hose with a box on each side like the botom part of the picture acept on both side or do they make a male to male adaptar |
http://store.summitracing.com/largei...9977033erl.jpg
an adapter liek that should screw into the top end of the line in the pic correct?? |
