how hard is it to assemble an engine?
To do it right you need a lot of special tools. I've assembled motors that ran just fine before without measure a single clearance though. Just slapping them together and run em. I don't suggest doing this though, I've killed a motor this way also.
To do it right I suggest getting an inside micrometer at minimum and a feeler gauge. You might want to get a camshaft degreeing kit also. Depending on your top end setup if it isn't stock parts you should get a pushrod length checked as well.
BTW where do you get a DIY short block from. I'm not familiar with woody?
ya i understand there are special tools and things that need to be done, just wondering if it woudl be out of reach for myself. Im 21, have done cam swaps, tran swaps, rebuilt rearend, put in a shift kit, and a load of suspension, so i do know my waay around cars. My dad would be helping with the process
Jim Woods, owner of www.FordStrokers.com
If you have done all that work, then you should have the right tools.
Ring compressor
Torque wrench
Shouldn't need bore gages and what-not for Jims parts...
Ring compressor
Torque wrench
www.fordstrokers.com
a lot of the guy's on here have used him, and they all say greathings about him
It kinda like having sex for the first time, your nervous and excited and you really want to do for braggin rights so you can tell your friends i built that/hit that. but its not that bad once you get started. just take your time and do it right, no short cuts.your only cheeting yourself. get a good manual and dig in.
Make sure your block is clean (never assume anything is ready to build)
Make sure you use a good assembly lube
Clean each part before you install it (just blow the dust off)
Look over every part carefully to check for nicks, cracks. (I've seen brand new pistons with cracked skirts that were damaged during shipment)
Make sure to check your clearances, double check anything you torque make sure you index your rings and if you are ever in doubt about anything, stop and ask someone. Don't let your pride get in the way
I can't put enough importance on having a clean place to build your engine and keeping your hands clean during the build. Buy yourself an engine bag (it's just a big thick plastic bag) to wrap your engine in while you are away from it. It keeps the dust, dirt out of it while you are away from your engine.
It's not hard to do and when you get done and are driving down the road it will be a rewarding experiance that will never leave you. Personally I think it's a great idea and buying a quality stroker kit Shortblock from someone who has a great reputation insures you are getting a quality product instead of buying a cheap Ebay stroker kit and throwing it into a questionable block.
I've been doing this for a long long time and I still get a little giddy when I fire up a new build. I think it's a mans way of giving birth, lol
I had been looking into the same kits a little while back, so far I havent rebuilt a 302 bottom end, but I have done a 429, 460, 400M and 3.8 V6 (dads SC Tbird lol). Its really not hard, its all been said above
