Been awhile, but project is moving along...
Yeah, it's got a Powerglide with a Bradco converter.
Hope it's done by spring, still alot left to do. Kit is almost done, but not quite, and still needs to be coated. Still have to wire up the BS3, tie up some loose ends and just get it running. Not sure what times it will run. Boost will probably be in the 20-25psi range. Once the tune is straightened out, I think it should run well into the 5's in the 1/8th, low 9's maybe high 8's in the 1/4,but you never know. It's a street car, so anything fairly quick and I'll be happy. If it doesn't go quick enough, I'll just have to put a bigger snail on it.
I don't have the brakes I need yet, so I have to watch it.
