Been awhile, but project is moving along...
Wow, very clean build, you're obviously someone that takes pride in their car.
Couple questions for ya, where did you get your alternator bracket and that piece that looks like a tie rod? Also, is that a standard or reverse rotation water pump and what size is that belt? My apologizes for the 20 questions, I'm just trying to pick up some info for the build I'm doing this winter
it looks like a march alternator kit and standard rotation w. pump
looks good dirty , again refresh our memory as to the build and goodies
also so how do u plan on plumbing the rest of the pipe from the intercooler to the tb?
Sonic,
It's the March setup, and a standard rotation water pump (yes, it took a different timing cover). The belt is 41 3/4" if memory serves me correctly.
jt,
Boss block 347cid, Probe Industries Dominator rotating assembly, Cam Motion custom grind, ported Twisted Wedge heads, Super Victor intake, custom Quicktime kit, Precision 78mm, air to air, Big Stuff 3, Precision 95lb injectors, Magnafuel fuel system, etc.
jt,
ahh a quicktime kit thats right i was lokking into those a little while back seem to be a decent kit,
so how are u routing the rest of the pipe to the tb, just curious as its pointin back to the firewall and your running a intercooler right?
