What suspension mods should i do?
I just got the eibach sportline lowering springs, the red ones, anyways what should i do next? i want my car to be able to handle extremely well around corners at higher speeds so what mods should i do that will get me there
x2
if you dont match the dampners to the springs you could get a worse than stock handling
subframe connectors make a HUGE difference in a fox that would be the first thing I would do because the lower the car the harder to work under it... depending on how you install.. make sure you get the weld in. Bolt in are a waste. Look at the UMI product. Best I have found, MM being close behind
Matt's 95 Stang
10-05-2015 07:16 AM
