POST UP your WISHLIST
#21
Depending on how hard tax season will be to survive and oil prices stop dropping off. This is what I will do in 2009 to my little coupe.
408cid
1996 Stock 351W, all machine work that will be necessary
ARP studs top and bottom w/ main girdle
Fully forged internally balanced rotating assembly, high compression ratio
AFR or Trick Flow High Ports - 205cc
Big Ol Solid Roller bumpstick
5000 stall for my Redneck C4
Better internals for my rear, aka bigger axles, full spool kinda stuff
Going to do a full front K-member swap.
I'm sure I am forgetting a few things. I plan on a 9 second index N/A or the car will burn.
408cid
#22
New exhaust from the headers back
Shocks and struts
Toss the small rear end for an 8.8 with gears, upper and lower control arms.
Subframe connectors
New paint
Upgrade transmission (haven't decided what to yet)
I'm sure there are things I'm forgetting.
Shocks and struts
Subframe connectors
New paint
#23
MMmmmmm........ what i have left to do (i decided on my build finally)
in addition to everything i already have(mostly suspension)
motor
ported, 1.94 1.5 valves, worked bowls '66 289 52cc heads (have just not on yet)
head studs, rocker studs, harland 1.6 rockers(have the rocker studs)
comp xe270 lsa114 w/ supporting springs
hardended push rods, guideplates
standard rotation timing cover
standard rotation water pump w/ ribbed pully
Ignition
mallory packages (dizzy, box, coil and wires)
Suspension
summit star wheels 15x10 rear, 15x4 front
MT ET streets 275/50/15
UPR double adj control arms(thats if my current UPR solids dont work out for me)
PA racing tube K member, tube A arms w/ perches
fuel
braided lines AN fittings(may never happen but they look kewl)
30# injectors
drive line
aluminum drive shaft
LSD 31 spline
31 spline axels
and someday if my trans breaks...TKO500
power adder
100 shot zex nitrous with all the goodies
im sure there is more, im just forgetting what it is. most of that i should have by end of spring early summer if everything works out to plan.
thats pretty much the list i decided on, the goal is to hit a mid 11 but i'd be happy with 11.99 lighting up on the board
motor
Ignition
Suspension
fuel
30# injectors
drive line
LSD 31 spline
31 spline axels
power adder
#24
Lets say we left the motor as is, it's built and nothing TOO major(no supercharger ect.) so it should last a while, I would add to it a Tremec/TKO trans, and a Ford 9" rear end. Basically just stuff to make it SUPER reliable and unbreakable, maybe some other suspension stuff, 5 lug conversion ect.
#25
After Iraq Plans
1. Sandblasting entire car
2. Fixing all rust
3. Replacing bumper covers
4. Paint
5. Replace windshield
6. New springs and struts/shocks
7. Lower control arms
8. Poly front bushings
9. Cam
10. Wheels and tires
11. Tint
12. Headers
13. 8.8 with gears
14. New interior with SN dash,console, and seats
15. T5 swap
The question is what will I really get to accomplish
2. Fixing all rust
4. Paint
9. Cam
11. Tint
12. Headers
13. 8.8 with gears
15. T5 swap
#26
Install all the parts I have sitting in my garage :
GT40P heads w/1.7's
GT40 intake
Steeda 19
Steeda X2s
Bumpsteer kit
3" swaybar endlinks
Rear axle bushings(on the housing)
KYB AGXs all around
And to purchase :
Paint and Vortech
GT40P heads w/1.7's
GT40 intake
Steeda 19
Steeda X2s
Bumpsteer kit
3" swaybar endlinks
KYB AGXs all around
And to purchase :
Paint and Vortech
#27
Just fix it up to keep it going
Rebuild the trac lok
Figure out why my tranny grinds when I down shift inot 4th
and fix a couple things paint wise....I have a broken trim peice tha need to be repainted and a couple of touch ups
#30
Engine, trans and rear are done but a lot of small related part left to go but here's what I can think of.
Maximum Motor sprorts Rear lower weight jacker control arms
MM adjustable uppers
New fuel tank with open pickup
Torque boxes welded up
Autometer Cobalt gauges (5 inch tach w/shift light, 2 5/8 oil, temp, trans temp,volt)
Fuel pump and lines (still undecided to go manual or electric)
Black Magic S blade Fan
New front seats (undecided)
Rubber floor cover
New Weld Prostars 15X8 rear 15X3.5 front
Pair of Flowmaster super 44's
Modify trans mount to get the rear if the trans down 1/4-3/8 inch so collectors will clear cross member.
In for paint by March
Rubber floor cover
