cutting springs pros/cons
thanks, and rubbing wasnt an issue from lowering, even with the 10.5s in back. however on a full crank turn, i cant remember which but one side i had noticed a long time ago looked like it had rubbed on the control arm. but that was before the lowering and its not any worse now, plus i just remember to not go full crank.
Being that the stock springs are linear rate cutting them shouldn't have much effect on the ride. Like mentioned I probably wouldn't cut much more than a coil. Also don't be surprised if your stock struts wear out faster once you drop the car, and get an alignment or you'll chew up your tires.
I cut mine and my ride is pretty good. I got a little greedy with it but it looks good,
I just gotta watch out for high spots in the road. It handles alot better now. I dropped 2 1/4 inches all the way around.
Front before
http://s284.photobucket.com/albums/l...7080235-00.jpg
Front after
http://s284.photobucket.com/albums/l...9080210-00.jpg
Rear Before
http://s284.photobucket.com/albums/l...7080236-00.jpg
Rear After
http://s284.photobucket.com/albums/l...9080211-00.jpg
Side shot
http://s284.photobucket.com/albums/l...urrent=024.jpg
Front before
Front after
Rear Before
Rear After
Side shot
