Calling all turbo guys!!!!
Old 01-05-2009, 07:12 PM
hillbilly pony
hillbilly pony's Avatar
Default Calling all turbo guys!!!!
OK here goes the brake down of the engine.
69 Block....adding 4 bolts or girdle or both.....have all just havent decided
Trickflow R heads (as cast)
Crane valve train
Custom crane cam .672/.672 adv duration 304/312 lobe sep 112.
408 stroker kit (cast eagle crank) forged other wise.
high vol oil pump
Pro-Systems carb.
Areomotive A1000 fuel pump...
Now for the actual question...
I have a T3 turbo from a 83 T/C. I was curious if this would be a good 8-10lb boost turbo for this motor...
AND...
what would i have to add/modify to make the turbo work with a carb??
hillbilly pony is offline
Old 01-05-2009, 07:17 PM
cammedlx
cammedlx's Avatar
Way too small for that much ci..Unless you plan to run two.And there's really no mods needed to be done for the turbo..Just blow thru carb,hat,hot & cold piping etc...
cammedlx is offline
Old 01-05-2009, 07:28 PM
hillbilly pony
what about BOV's and timers and fuel requirements etc??
Old 01-05-2009, 07:29 PM
hillbilly pony
Also what would be the suggestion for a single turbo (minimum size)
Old 01-05-2009, 07:33 PM
hillbilly pony
it is a .60/63 if that effects anything
Old 01-05-2009, 08:20 PM
Hung Like a Stang
Hung Like a Stang's Avatar
I'm using two of those on a 306. You're going to need a big turbo if you want to go single. Even two of those are too small for a 408.
Hung Like a Stang is offline
Old 01-05-2009, 08:21 PM
luckythirteen13
luckythirteen13's Avatar
turbo is WAY to small for a 408. i run two t3/t4 turbos on my 331. you need something in the 76mm or larger range. the 4 bolt idea is a total waste of money unless the block is 4 bolt from ford. if its a two bolt block there isnt enough metal to drill out for the extra bolts. youll just make the block weaker.
the a1000 is a good pump, its what i run. its rated at 800hp on boosted motors but ive heard it starts to run out at 600-650rwhp.
luckythirteen13 is offline
Old 01-05-2009, 08:32 PM
Hung Like a Stang
http://www.theturboforums.com/smf/in...?topic=98156.0
Old 01-05-2009, 08:33 PM
hillbilly pony
Good info guys......so lets see....
76mm turbo...............$2000
300 shot of NO2.........$600
Got it!!!!
LOL
Old 01-05-2009, 08:50 PM
luckythirteen13
Got it!!!!
LOL
and thats just for the turbo.
if you do go the nitrous route, plan on spending more then $600 for a 300shot. youll need some sort of fogger or plate setup for that much juice. window switch, WOT switch, bottle warmer, etc, etc. of course thats if you want to do it right.
Quick Reply: Calling all turbo guys!!!!
