Kenne Bell on 93 lx. Need Help
if you're gonna get a tune and run the 8lb pulley, 30# injectors min, i'd say 42's would be right. yes you should get an adj. FPR w/ a gauge on it.(kirbans are cheap and work well) 255 pump is perfect. you really should run a larger MAF and TB than 65mm but as long as the MAF and TB at least match you arent really hurting yourself. make sure your intake can support that size of TB though.
