starter problems still
Old 01-12-2009, 03:57 PM
gtmustang1090
gtmustang1090's Avatar
Default starter problems still
i replaced ignition switch, starter, celinoid, and starter wire. and the starter is still hanging up and wont disengage from the fly wheel.. any ideas
gtmustang1090 is offline
Old 01-12-2009, 04:36 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
It doesn't disengage at all?
projectresto83 is offline
Old 01-12-2009, 07:22 PM
Catchpole
Catchpole's Avatar
Mine did this and it was the starter relay, a quick fix is to gently but firmly hit it with a hammer/decent size wrench...Seriously... it's just not disengaging, or at least mine wasn't.
I did that once or twice and then I just replaced it.
Catchpole is offline
Old 01-12-2009, 08:19 PM
camaroeater
camaroeater's Avatar
+1 on tapping the solenoid to disengage the starter. The first solenoid I installed turned out to be defective, then i bought a more expensive one and the problem was solved.
camaroeater is offline
Old 01-12-2009, 09:46 PM
gtmustang1090
Angry
i am on my 3rd celiniod because i returned the others.. and then went and got a more expensive one you could feel the difference in weight.. no help.. the car will crank and start just the starter wont disengage after i start it.. then i have to turn the car off and its still cranking off the battery till that dies or i hop out and pull the cable off the battery.. someone told me the one red wire going into the celinoid is what tells the starter when to engage and disengage.. if this isnt it i have no clue.. i finally got talked into buying a ford and its been the biggest mistake that ive made so far since ive had it.. the car is killing me sitting in the driveway.. i wanna go tear the streets up alittle with it
Old 01-12-2009, 10:04 PM
projectresto83
M.A.D. Motorsports
My 89 4 cyl did that. I got tired off it and sold the car.
I didn't have a title for it anyway. Then my cougar started doing it, I hooked up toggle and a push button start and solved that one. I loved that car lol
Old 01-12-2009, 10:14 PM
gtmustang1090
yeah i wanna keep the car like with a key start.. im not quite sure what the issue is but it is pissing me off big time .. im gonna try this wire that the local mustang speed shop guys said it sounds like.. if i cant get it hes gonna have the car to figure it out..
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
jaiidutch
09-14-2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
Quick Reply: starter problems still
