crate engine question
i found the crate engine i want to put into my car...the question i have is it says can be built for fuel injection and there system is 3000...since my 89 is already fuel injected is there a cheaper way to do it?
heres the link the motor if it helps http://www.tandlengines.com/ford_sb_347_A_2.html
Yea, take that motor and pull the intake and oil pan off and slap yours on it along with everything else your car has that that doesn't to make it run. Keep in mind though your dyno numbers would be lower than what they advertise simply because a carbed setup over a EFI puts out more power with the same package.
HIS S-197
08-10-2015 05:47 PM
