on flexplate is only this: EOSP-AA and AOD letters, it has 164 tooth. I will be greatful if you can find out what balance is it. Now I must go to sleep. I Poland its 11pm.
Has the motor been changed in the car before? From what I have found the flexplate part number should be E2AZ-6375-A.
Have you put the automatic in the other car? Does it vibrate also?
If the flexplate is not in the car check and see if there are in other numbers on it. That number does not look like a complete casting number.
Both flywheels look like a 50oz counterweight but I don't know.
EOSP-AA this only thing that is on flexplate. When car has auto it works good, I drive this car everyday. now with t5 starts to shake. A for the engine swap I don't think so, this Is stock car.
no, I don't have time :/ I'll pull it in monday. were exactly could I find enigne numbers ?
When you pull the tranny unbolt the bellhousing. Put the flex plate on the car and the bellhousing and start your car, and see if there is a vibration. I have looked everywhere on that E0SP-AA number and come up with anything.
it,s impossible, flexplate is bigger then flywheel, fly has 157tooth, flex 164 tooth. To check vibration I must put aod again but this will be my stock setup.
I will try to put it back together in monday. This isn't rubbing sound, it's just vibrating feeling on engine and whole car, I thing it's becuse there are no pilot bearing and clutch disk is bouncing but I must put it to be sure.
