cold weather mpgs...
#21
Fix the odometer and get some GOOD data for next winter... until then you're just guessing.
I have noticed my 2.3 n/a daily driver (~115mile/day) drop roughly 2mpg (from 29-30mpg) during the winter months, but I can't positively conclude what the drop was due to... Could be in the tune...
Any of you guys look at the impact the ECT/ACT temps will have on fuel/timing calculations
#22
Bill the most likely source in drop in mpg around here is fuel in that from Nov-MARCH I believe they run oxygenated fuel, I have an 81 jetta Diesel with NO ECM = all old school......and I have played with the injection pump timing to max mpg and in the summer months 50 -52 mpg and in the winter months 45-46 sometimes less...no matter what I do in the winter it's always less and right around when they switch back to the summer fuel here which is march/april I believe is when my mpg picks back up
#23
Bill the most likely source in drop in mpg around here is fuel in that from Nov-MARCH I believe they rum oxygenated fuel, I have an 81 jetta Diesel with NO ECM = all old school......and I have played with the injection pump timing to max mpg and in the summer months 50 -52 mpg and in the winter months 45-46 sometimes less...no matter what I do in the winter it's always less and right around when they switch back to the summer fuel here which is march/april I believe is when my mpg picks back up
sorta makes sense now...
#25
I will have to look at mine, but I'm pretty sure the compressor doesn't kick on either.
#26
if the a/c does not have the proper charge in it then that part of the system will not work cause the low pressure switch will keep the compressor from activating
