What controls the fan on a '94?
Hi all,
I got my anderson pms hooked up, and I started tinkering with it. One thing I've realized is that my car has a thermostat that opens long before the fan turns on, so in effect the thermostat controls coolant temps when the car is moving, and the fan controls them when stopped or barely moving. I'd like to have the fan turn on much sooner, probably about 10 or 15 degrees after the thermostat opens. I figured that the pms would have an option to set the fan turn-on temp, but it doesn't. Is there a separate temp switch that controls the fan on these cars?
Nope.... fan is turned on by the CCRM module after the ECM triggers one of its internal relays based on the coolant temp readings from the ECT sensor. 208°F is the temperature for the ECM to turn the fan on low-speed.
