upgraded afr165 Q
upgraded afr165 Q
I have a aset of used afr165's with the chambers opened up to an equal 58cc or 64cc (cant remember) and the deck milled .020 topped off with AFM hi-rev springs. I am gonna be building my first motor and was wondering if a 331 or 347 would be to big for what I have. detailed comments would be great thanks
can the 165's be milled out to accomodate a larger valves? cc size and valve size is the only real diff right?
keep in mind that this is a DD and will not see any track time. - sorry forgot to mention
ya you can spend a bunch of money on them, DONT do that. If your going to do that then just think smart, sell them for 800-1000 and buy a 185 if you want
if its a DD i would just keep the 5.0 bottom end and spend money else where..
you can have a nice motor that makes plenty of power but that dosnt mean anything if you got no traction. i'd invest in some suspension mods.
so is a 302 the biggest everyone thinks I should go with these particular heads?
thanks for all your input
dont ever build a bottom end to match your heads. Unless you are forced to run a particular head for whatever class you are running.
Decide what you want to do, build the bottom end to get you there, then work upwards.
Its much easier to put on the proper head than it is to put in a new bottom end.
Exception being your head is in your plans, but dont build your engine arround a particular head (within reason of course)
slo50:
im not doing any racing of any kind just a summer fun cruiser. I happened to get these heads a pack of other stuff for a deal so thats why Im building around them.
Gary :
ya still running the origional t5 I assume as the car only has 58K on it. I understand that these earlier fox T5's had issues but mine works great except for the going into 2nd is a bit sticky somtimes but it might be the shifter not adjusted right either.
and ya subframes and control arms are gonna be done this summer I hope. after that I think I'm all set. right?
thanks for all your posts!!
Gary :
