Yeah, it's possible. Here's a slip from my wifes vert. Basically stock w/ gears and underdrives and slicks. Is a 5 spd though. She's a 1/2 faster sec in the short time though. That's makes a huge difference
3.55's. Prior to her best time, she was running 15.0-15.1 on 17" street tires. I put slicks on the car and you see the end result. There is a lot to be said about sticky tires no matter what power level you're running.
What size tier is she running in the rear and what kind? Oh does she have sub frame connectors?
I'd say you could do better back when my 85 was still runnin I had a flat tappet 302 in the car (so you know I was runnin low hp)but on 17" rims bald street tires and 3:27 in the rear I had a best of 15.4
sounds good. thanks for the input guys. im pretty satified knowing i should be able to get a hi 14 out of it. not bad for a dd aod mostly stock. i think i might bump the timing and add an electric fan before i go back to the track. also i might as well take out some tire pressure. and get that 60 ft time down. ill post result as soon as i can get out.
Your car was much faster than my AODE 95 stang. I ran a 10.3@67 1/8th. All it had was Flows, CAI, and shift kit. With TB, full exhaust UD pulleys and 76mm MAF, I ran a 10.1@71. Then I added 4:10's and ran a 9.39@78(2.4 60ft). Gears will make you car rock. Good runs BTW!
the 60's are horrible. put some slicks on it and youll go into the 14's easily. your times are about what my car ran when it had the same mods as yours does. stock aod will kill you
