The set up i'm going to use is trick flow track heat intake,30# injectors,big fuel rails,75mm TB,Trick flow twisted wedge heads,Procharger with 16# of boost intercooled.
In your case I'd get a custom cam especially with 16# of boost. Better get some bigger injectors while you are at it.
