Giggle Gas
Giggle Gas
so i was thinkin of puttin juice to my car, you know to show some of those damn rice burners whats up lol, but anyway what is the the best inexpensive kit to get and what can my motor handle as described by my sig???
why would you not hit it with more than a 100 on a stock block? i have seen 200 on a stock block with no problem unless you mean dont go over 100 with a dry shot then yes i would agree. i have seen stock 5.0s take a 200 wet shot all day long with no problems
the solenoids are all made by the same company in china just have the different nitrous band stickers on them, bottles all have to pass the same tests and specs so they are all the same too. it really comes down to what you like.
Although the pistons are "Forged" they are cheap TRWs, then you have to consider the other stock components in the block and the head gaskets that prob havent been changed in years as well as stock headbolts. I feel like 100 shot is the max safest amount I would use on a stock block. None of it is "Safe" but some people can get away with more. We ran an old 455 Buick with cast pistons at least 20 passes before it let go.sometimes you just get lucky sometimes you don't. I use to fill Nitrous bottles in my shop. I saw a lot of guys who brought by their broken parts to show me. The 5.0 crowd was by far the biggest Nitrous users where I was. The guys running 100 or less were having the bottles filled once a week or more. The guys running 150+ were the ones showing me thier collections of burned pistions, head gaskets and broken carb plates. When you are in this business for long you see patterns develop.
I know for a fact Nitrous Express solenoids are built in the USA. I'm fairly certain Edelbrocks Stainless soleniods are as well. Even if the rest are built in China in the same plant there are vast differances between differant companies. (example) Puralator builds a lot of differant companies oil filters that come down the same assembly line. Lot's of differance in the filters when the brand name changes because they are built to brand spec.
i find the people that blow up their engines are the ones that get very greedy with timing and fuel and dont take the added precautions like window switches. a 150 is perfectly fine in a stock 5.0 as long as its a wet shot not a dry and you run the cooler plugs and retard the timing. its the people that get too lazy and dont back the timing down because they dont want to loose that hp when not on the nitrous i find are the ones that really hurt their engines. you also have the guys that have the button and not the WOT switch and double hit the button or hit it too soon that blow stuff up too.
