Hey guys, I picked up a used super charger and I need to get a new super charger to throttle body tube and a BOV because I will be running about 12 psi. Where is a good place to buy? Cost is somewhat of an issue but I dont want junk!
or i believe you can go to the manufacture and get the piece , and why do you need a new one? a lil confuessed? to change the psi you just change the pulley size
Corral.net has tons of used parts that you are looking for. I bought my Vortech from their parts forum. Also, you CAN run the stock bosch bypass valve with 12psi(I am running 15psi through the stock one). And as for blow off valve, you cannot run one unless your MAF is a blow through MAF. A bypass valve works with the draw-through MAF, so I am assuming you mean the bypass valve.
