Just to make sure: 95 world class T5
Im going to do the T-5 conversion from my slow AODE this summer. I found a T-5 out of a 95 GT and want to make sure it will work with mine. He calls it a "world class" tranny. Is that what I need?
Is there some numbers or something I need to know for sure that it will fit? thanks guys
as long as your sure its a 94-95 T5 then yes it will work in your picture in the sig. if its pre 94 then you need to replace the input shaft with the longer 94-95 input shaft.
world class is nicer because it doesnt use brass blocker rings on the main gears except for 5th/reverse
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
