Ebay H/C/I build ...Excitement! :)
Am I the only one who thinks that cam's a tad big for P heads??
aside from that, nice buildup. Should have some pretty good grunt downlow. & With a drivetrain like that on slicks you should turnout some good numbers at the track.
No offense though, i dont see it hitting that 300 mark like someone said. I say ~270WHP.
hit it with a 150 shot and i bet youll pull the wheels with them slicks
Cam
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 2,200-6,200
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift: 224 int./230 exh.
Advertised Intake Duration: 276
Advertised Exhaust Duration: 282
Advertised Duration: 276 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.544 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.544 in.
Valve Lift with Factory Rocker Arm Ratio: 0.544 int./0.544 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Intake
* Small cross-section 15.000 in. runners
* Idle-5,500 rpm range
* 75mm throttle body inlet
* 2.000 in. x 1.200 in. port size at cylinder head
* 10.200 in. overall height to the flange
Heads
Valve Size: 1.84 intake 1.46 exhaust
Chamber Volume: 60 cc
Intake Runner volume: 145 cc
Valve Spring (seat) 90 lbs @ 2.00
Valve Spring (@ .500 lift) 310 lbs @ 1.500
Valve Spring (coil-bind) 1.300
Retainer To Seat Contact 0.75 intake/ 0.77 exhaust
Ex/Intake Flow Ratio 66.8 @ 5.00 lift
Anything else?
Intake
Heads
Anything else?
If I were you I'd be rethinking that cam choice. The XE276HR is designed around 1.7 rockers and not the factory 1.6. That cam has a peak torque that comes in around 5000 rpm and your heads and intake will run out of breath around 5500 so that only leaves you a 500 prime curve that will render the engine weak down low. I'd back up to the XE266HR and that will widen you up to a nice power curve of 1500-1800 rpm. The cam still leaves a little room if you decide to do a little porting on those haeds and intake. Not quite as much thump at idle but will be quicker down at the drags.
Agreed
My apologies but I posted the wrong specs for the heads. I went to the site from-which they came "Tri-state Cylinder Head" and these are the actual specs of the heads:
60cc Combustion Chamber
Pedastall Type Rockers Used
Positive Oil Control Seals
5 Angle Valve Job
Stainless 1 Piece Swirl-Polished Under-Cut Stems 1.940” Intake Valves
Stainless 1 Piece Swirl-Polished Under-Cut Stems 1.540” Exhaust Valves
AWSF-32C Spark Plug
Springs Good to .550” Lift, (Hyd. Roller)
(129 psi @ 1.800” / 280 psi @ 1.300”)
Does this change things some?
I understand the track heat would of been a better match to my cam (intake rpm range 1500-6500 cam rpm range 2200-6200) but a few others and I agreed that it would of been too much intake for my combination.
5 Angle Valve Job
AWSF-32C Spark Plug
5 Angle Valve Job
AWSF-32C Spark Plug
5 Angle Valve Job
AWSF-32C Spark Plug
