when we took the mach 1's old engine out, we used some brackets that were basically a peice of angle iron with holes drilled in both surfaces, one bolted to a corner intake bolt (so they were across from each other) and then we put a chain on the hook of our cherry picker, and then bolted the chain to those brackets, seemed to work well...
thinking about it, id prefer the accessory/thermactor holes, bigger bolts=less likely to break
