MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   5.0L General Discussion (https://mustangforums.com/forum/5-0l-general-discussion-87/)
-   -   The epic quest to 12's (https://mustangforums.com/forum/5-0l-general-discussion/522326-the-epic-quest-to-12s.html)
Jeankrist Mar 5, 2009 11:44 PM
89 mustang gt 5spd mods:bbk shorties/American thunder flows cat back/3.73's/removed air silencer/K&N filter/stock heads and intake.
After tons of reading, questions, and threads started I believe these mods will launch me into high 12's herebare the mods and price let me know what you guys think.
Summit lowering springs $137.50
Sumitomo HTRZ high perfomance (275/40-17) back tires $236
Nitrous outlet kit from lmr.com $499.99
Bbk 255lph fuel pump $129.99
Summit H pipe 2.5in $98.95 or bbk Cnc o/r 2.5in H pipe $179.99
J&M full length sub frame connectors $99.99
Maximum motorsports lower control arms $249.99
March performance under drive pulley kit $51.88
I plan on hitting it with a 100 shot and also putting the fox on a diet to drop some weight um this is what I have come up with about the H pipes I have no idea which to choose between summit or bbk inputs would help also will this put me in high 12's? I'm guessing also maybe 300 rwhp with the shot. Anyways remember this is a daily driver that will see track time on weekends again any inputs or suggestions or hell even a better build for the money I will pay for this one will help
AdderMk2 Mar 5, 2009 11:56 PM
you sure as **** arent going to do it on those HTRz tires...
and dont waste your money on the UDP's... lowering springs arent going to help either
BlessedHellride Mar 6, 2009 12:00 AM
leave like your at a redlight if you are on stock tires. maybe about 3rd you can indouce the spray, but from a dig, you will be digging a grave. It will be much fun from inside the car and driving it, but it wll suck from the E.T. boards at the end of the tracks.
Jeankrist Mar 6, 2009 12:15 AM
Well wat do u suggest for tires? And why ud pullies? I thought the were a good bang for the buck kinda thing?
BlessedHellride Mar 6, 2009 12:21 AM
U/D pullies might get 5 hp to the tires, but can usually cause more charginging and cooling issues than they are worth. As far as tire, I only like the M/T tires. I run a drag radial, but to each their own
Jeankrist Mar 6, 2009 12:31 AM
how much r M/T I plan on running drag radials will I be able to drive the car with m/t drag radials in the back and regular tires in front on the streets?
BlessedHellride Mar 6, 2009 12:34 AM
M/T radials in the back are what I run. It's not my daily driver mind you. But it works fine. When traction is that big of an issue, money is no factor.
AdderMk2 Mar 6, 2009 12:54 AM
M/T's in the size you are looking at... $208 each... Nitto's, around $165
Alex-7 Mar 6, 2009 01:16 AM
Nobody seems to have mentioned it.... but since it's in the title of the thread I figured I would.
Bolt ons and a 100 shot will get you into the 12's no problem.
/thread.
Edit: How 'bout some 555's for tires?
Jeankrist Mar 6, 2009 02:04 AM
/thread.
Wat do u mean by bolt ons? Cause I know some people that consider hci boltons if that's what u mean then prob not cuz hci would run anywhere between 1800 to 2000$$$$ and dats not even including a nitrous kit
© 2026 MH Sub I, LLC dba Internet Brands
