Msd 6al-2 with 2-step rev limiter
thats a great deal and its very easy to hook up. there is harness you can buy so that the 6al is plug and play. the 2 step is a little more difficult. it plugs right into the 6al but to activate it, you need to run a wire from a 12v sorce to a button inside the car, then to the 2step module and then ground it out.
what tranny do you have? if manual, the button inside the car will be a switch on the clutch peddle to activate the 2 step. if an auto, then the button would be the same button you have for your transbrake or just a button that controls just the 2 step
treesloth
09-28-2015 07:03 AM
Offendant
09-23-2015 07:21 PM
