Is this cheap?
Is this cheap?
I was doing some lookin around on craigslist and found this cam. COMP CAMS CAM (GRIND # 35-450-8) 598/598 LIFT 286/286 230@50 106 LOBE SEPERATION $115. What do you guys think about this cam? Good deal?
nevermind I found the grind on summit........what are your intended uses / mods for it??
http://store.summitracing.com/partde...8&autoview=sku
Thats an old magnum grind. I wouldn't install that thing on anything that wasn't sporting some good heads, 10+-1 compression steep gears, and a 650+dp carb. It would make some killer mid range but the XE line is a little better. It's only a good deal if it fits your needs. I don't think I'd throw this one into a fuel injected engine
