help! looking at a fox maybe? - MustangForums.com
Old 03-11-2009, 02:01 PM
racin66coupe
racin66coupe's Avatar
Default help! looking at a fox maybe?
i need your guys's opinions, hes asking 1500 for it now.
http://nh.craigslist.org/cto/1062692017.html
what could the 2nd gear grind be?
in another one of his ads it says the pass door sags but no rust?
racin66coupe is offline
Old 03-11-2009, 02:15 PM
JKS89
the grind is probably the syncro or could be as easy as a clutch
JKS89 is offline
Old 03-11-2009, 03:09 PM
racin66coupe
anyone have any opinions?
Old 03-11-2009, 03:35 PM
Five0hFox
Five0hFox's Avatar
Sagging door probably just needs new pins and bushings in the hinges.
Five0hFox is offline
Old 03-11-2009, 03:51 PM
Timspony
SVT Section Moderator
Timspony's Avatar
...for $1500 & some TLC not a bad deal if the car runs good & is not a rust bucket!
Timspony is offline
Old 03-11-2009, 03:53 PM
racin66coupe
you think so?
Old 03-11-2009, 04:47 PM
steel1
steel1's Avatar
If no major mechanical or rot issues, sounds like it could be a good project. Just gotta remember good bodywork/paint are expensive.
steel1 is offline
Old 03-11-2009, 05:06 PM
javier146
javier146's Avatar
Yep, prices for body trim and body parts are ridiculous. 200 bucks for door trim. Just make sure all the side skirts and ground effects are in good condition. I don't think you can find those parts anymore accept for a junkyard.
javier146 is offline
Old 03-11-2009, 07:00 PM
5.0 85 GT
check under the hatch and doors for rust...those mods may indicate a beat motor..check for oil soak all on the trans tunnel under the car...the grind is notorious in every 5.0....the second gear synchro is shot...for the grinding issue...other than that check it out..a nice cheap project...make sure you drive it though!!!and check the brakes!!!
5.0 85 GT is offline
Old 03-11-2009, 08:00 PM
BladeX10
Another ruined 4 eye =(
It could be a good car just as long as there is no major rust rot
BladeX10 is offline
HRnB
Off Topic
126
11-13-2017 12:36 PM
01-21-2016 01:30 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
RCS02v6
09-29-2015 01:46 PM
Glocker23
09-23-2015 08:19 AM
Featured Sponsors
