Spark Plug Gasket Question
so yeah, i was watching horsepower, and they were doing a TF H/C/I swap on their POS mustang, and they mentioned that Trick Flow required Gasketed Spark Plugs, and i said oh ****, thats what those are, adn yeah i didnt put the gaskets on mine when i did my H/C/I swap (i just checked...) so yeah, how important are these, im about to go buy new ones, as well as some new oil (its been about 8 months since the swap/last change, and im a quart low )
so for the septumpth time, 5 quarts, correct?
also, for a slight status update, im pissed off at my engine as a whole, so sometime this year (once the engine is in the hotrod) im probably going to pull mine, which will give me the opportunity to do a couple of things
1 Replace oil pan gasket with a 1 peice (its leakin like a bitch out the front, i have like 20 little spots of oil on my driveway where i park)
2 Fab up a hydraulic Clutch assembly my friend gave me (this was bought for the RX7 5.0 swap, so it has a wilwood Master cylinder and a custom pull slave to mount to a T5) so im hoping to find some room to get that bish to work)
3 probably install a custom cam, this crane one isnt cuttin it...
4 actually install a filter element or whatnot in my PCV. (once again, my ignoramus self didnt get one, last time i pulled the upper intake it had oil residue all over it...
5 install a baffle in the breather thing to the TB (see 4)
6 fix all of the bull**** my cars been throwing at me, including the stripped exhaust bolt hole on my pass. cylinder head...
so yeah, bleh
so yeah, bleh
yes 5 quarts is right and as far as the gasket on the spark plugs is prolly due to the the twisted wedge design to set the plug back for better combustion...prolly not that big of an issue if you dont have gaskets on them but hey do as you want is your ride
also, im looking on AFR's website (filling out a custom cam form for later use) and its saying that part number 1402 requires hardened pushrods
what the hell is up with that, i never saw that before, and ive got 1402's... and stock replacement rods.......
Alot of guys like to see the aluminum pull out before they heli-coil the holes. I don't know why, but I have heard machinist say that before. The crappy Pro-Comps I run are the same way on their threaded holes, just aluminum.
