coupe suspension pics
Well, I attacked the upper control arms 2 days ago. It was a b*tch to take out the stock sleeve from the housing of the axle...once i figured out how to take one side off...the other was rather easy. Once the sleevs were off, the install was a breeze. No issues what so ever. Kit was SUPER easy to get on. Took about 3 hours max to do the upper set up. Only about an hour for the lowers. I even took the needed measurements to get my IC (instant center). I need to drop my car about another .75 inches to get it PERFECT. The whole point here is to make the lower control arms PARALLEL to the ground. That is step one. I cut the stock springs. I needed 1.5 inches to make it parralel. I have half of that now. So another 3/4 of an inch and she should be ready to set the pinion angle. Here are some pics of it...let me know what you all think...
you do understand control arms need to be parallel to the ground under load? otherwise when you launch and you are squats a little bit you'll be negative degrees pinion angle.
also you made sure and torqued down the bolts AFTER you have the car on the ground?
other than that it looks good
i understand but confused with "control arms"
the lower control arms need to be parallel to the ground when the car is on all 4 wheels on the ground...ride height dictates the movement of the lower control arm
the uppers are not going to be parralel to the ground...
the uppers need to be set under load...170 lbs in the driver seat in my case
the pinion angle needs to be set at about -1 1/2 degrees...that way when the car launches the pinion angle is HOPEFULLY at 0 degrees....
i only weigh 170 lbs...no way i can fit under the car to torque the upper control arms...i seriously do no think they have to be torqued when they are on the ground...the upper arms pivot so it shouldnt matter...
i did drive it on my nitto drags and i can certainly feel the difference...doesnt spin in 2nd anymore on the street...
i'm sure my pinion angle is off a little but according to Kevin from baseline...it should be real close....gonna get on a drive on lift to adjust the angle on saturday once i bring the car down some more
you can most deffinately tq down the bolts with your car in the air. you do have a solid axle...put the jack stands under your axle...wallah! your vehicles weights is now on the suspension. have the bolts semi tight but not tq'd then tq em down when the suspension is under load. and yes if can make the bushings bind if they arent tq'd while under vehicle load. should even tell you that in the instrutions.
you took me for a spin with this comment, "torqued down the bolts AFTER you have the car on the ground"...thats why i said i wouldnt fit under there...lol
once i get the lower control arms parallel to the ground...im gonna have to lower the front stance...if not itll look weird
