The spacer dissipates heat more effectively than without one, thus creating more power. I actually tested it out with a guy at the drag strip. I had the spacer, he did not. His intake was much hotter than mine even after it had been sitting for an hour. I had just made a run ten minutes prior to the testing.It works. The problem is, you may have to modify your EGR.
