carb swap ?
04-07-2009, 05:24 AM
yea it has all the wires that come off the idtion switch have be cut at some time all then hooked back up so much **** has be cut under the dash and then hooked back up
04-07-2009, 05:22 PM
mustang runs great, car doesnt shut off when key is turned off
04-07-2009, 07:36 PM
D.R. THE PATHETIC DORK
something is wired wrong in the ignition switch, often times it'll kill power to the module or coil switch 12v, so you'll have to see what is wired wrong with the switch or bad switch even though you say it's new
04-07-2009, 07:56 PM
ok i will check to make sure the wires r right and if they r then i will take the switch back to advanced
04-07-2009, 08:04 PM
GOOD LUCK
04-07-2009, 08:33 PM
04-16-2009, 08:15 PM
ok so i got a throttle cable today for a 85 mustang and it is long as hell
04-16-2009, 09:05 PM
POST A PIC OF IT CAUSE MY 85 STOCK ONE IS NOT LONG AT ALL
04-16-2009, 11:14 PM
bradleyb
11-27-2015 07:50 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
guitarman376
09-30-2015 05:54 PM
