codes 91, 44, 61 after head swap
i didnt mess with any ground wires or anything like that
i moved the injector ground to the firewall last year because i got the the 91 and 44 codes
its saying bank 1 lean and hego not switching
code 61 says low maf ground but i cleared the codes and it went away
any idea's?
any idea's?
Well, it does, since if a higher priority code such as a HEGO not switching, could cause a lean problem which would create that code.
In newer cars with electronically controlled transmissions, and there's multiple codes set for the engine and trans, you solve the engine codes forst cause they can create the trans codes.
TfcCDR
09-14-2015 12:08 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
