42lb injectors question?
Old 04-12-2009, 10:59 AM
ponyboy88
ponyboy88's Avatar
Default 42lb injectors question?
http://www.buyfordracing.com/shop/pr..._id=635cPath=9
Was looking at this and wanted to know if i would run into any isues with these on a street car. They say they are runned for race applications, also, what else do i need to install a lighting MAF on a fox thats already MAF.
ponyboy88 is offline
Old 04-12-2009, 11:12 AM
grabbem88
grabbem88's Avatar
please don't be confused with the "race application" comment same people will say long tubes off road h/x pipes are race only parts...go figure.
have you looked at anderson ford at there combo deals yet?
$279 isn't bad at all,but if you are doubting the install at all ...i'm sure there is a post about the wiring and install
grabbem88 is offline
Old 04-12-2009, 12:23 PM
luckythirteen13
luckythirteen13's Avatar
just get a pmas maf, better quality then the lightning maf and its actually designed for your car.
luckythirteen13 is offline
Old 04-12-2009, 12:28 PM
grabbem88
grabbem88's Avatar
true my 95mm pmas now on a different car is/was a great investment...just wasn't sure if he/op would go for it?
Old 04-12-2009, 01:10 PM
ponyboy88
ponyboy88's Avatar
i wont be hitting the engine building stage for a while, but trying to grab deals as they come. if the pmas is of a noteworthy quality then i'll take you at your word. thanks.
Old 04-12-2009, 01:16 PM
grabbem88
grabbem88's Avatar
then you are on the right track..
check out anderson ford look at what he has...got some trick stuff over there..
Old 04-12-2009, 02:24 PM
AdderMk2
Banned
AdderMk2's Avatar
hope you dont plan on running those on a stock motor
AdderMk2 is offline
Old 04-12-2009, 03:02 PM
ponyboy88
ponyboy88's Avatar
haha, nope. Plan is a KB blown 347 Boss
Old 04-12-2009, 06:11 PM
grabbem88
grabbem88's Avatar
with a boss block/347/blower...you might need to be looking at 60's or more if you build it right
Old 04-12-2009, 08:27 PM
ponyboy88
ponyboy88's Avatar
it'll be on the milder side, but yea, 60's prolly. Goal is 500 to the rear...if at all possible, would be interested in you suggestion of "building it right"
Quick Reply: 42lb injectors question?
