I bought this 91 5.0 convertable about a month and a half ago. This car is driving me crazy I have an issue with long crank times the idle air control has been replaced thats when this problem started. The idle air control was replaced because it kept dying out, now it cranks really long before it will start, then it has an intermitten high idle. Any ideas?
do you have a fuel pressure gauge? extended crank is sometimes caused by fuel pressure leak down. either damaged line or damaged check valve in the fuel pump.
Yes the fuel pressure has been checked and the filter replaced which looked like coffee with cream coming out of it Yuck! But this didnt start untill after the iac was replaced thats why im confused
