Used gears (HELP)
have him send you pics. it should be stamped on the end of the pinion gear if they are factory. if not count the teeth on the ring and then on the pinion. then divide the numbers(ring teeth / pinion teeth) this will give you the ratio. for example 41 ring gear teeth / 11 pinion teeth =3.727 gear ratio.
I'd pass on the used gear set. You may be taking on someone else's problems. Gear sets are cheap enough that there is no good reason to go with a used set. This is a real case where you could trip over a dollar to pick up a dime.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
